Old 06-25-2006, 06:28 PM
Glasair34me Glasair34me is offline
Default Half Roll or Half Loop?
I couldn?t resist. After reading Martin?s post about the paint gun, I had to ask you all a question. When a fly lands on the ceiling, does he do a half roll or a half loop? I can?t wait to hear what you think!
Scott
RV-8A,Skybolt
Glasair III;finishing
Old 06-25-2006, 06:34 PM
fred fred is offline
Wink
it all depends on which maneuver he/she uses to land on the ceiling.
Old 06-25-2006, 07:51 PM
szicree szicree is offline
I've actually seen high speed footage of this very thing, but I can't remeber which way he did it. I do recall that he planted one foot against the ceiling and pivotted on it. I'll bet the video is on the web somewhere.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 06-25-2006, 08:21 PM
dan's Avatar
dan dan is offline
If you believe everything you read on the internet, then here's an answer...
A) Neither. For a long time, people believed that the common housefly, Musca domestica, performed a stunt pilot's half-barrel roll when approaching the ceiling. But in 1958, freeze-frame photography revealed that something else was going on. As Caltech insect physiologist Michael Dickinson explains, first the bug-eyed fella flies right side up at a low angle and in a direct line toward the upper deck. Just prior to impact, it instinctively extends its forelegs over its head and grabs the ceiling, using hooks or sticky pads at the ends of its legs. With the fly's front feet firmly grounded, momentum swings the lower half of its body up, like a trapeze artist. Spider-Man's got nothing on Superfly.
From http://outside.away.com/outside/feat.../wildfile.html
Dan Checkoway RV-7
Old 06-26-2006, 08:46 AM
Jekyll Jekyll is offline
I thought it was more akin to a Lomchevak (sp) than a loop or roll.
Jekyll
