  #11
Old 08-08-2007, 12:22 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Yes...
Originally Posted by cnpeters
Has anyone had mush use for Permatex Red Silicone RTV? Label says for high temp application.
It's good for sealing small air leaks in the engine baffles, and at the baffle to engine interface.
It can also be used to reinforce specific sections of SCAT ducting to prevent abrasion.... just smear a thin layer on with a wet finger...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-08-2007, 12:25 PM
w1curtis's Avatar
w1curtis w1curtis is offline
Originally Posted by mlw450802
I don't think Permatex had anything to do with Hylomar.
http://www.hylomar-usa.com/?siconten...ckingid=672078
Do a google search on hylomar and there are lots of hits and many active online sources.
I just recently purchased a tube of hylomar blue within the last month or so.
-mike
What is Permatex Hylomar HPF?
Hylomar Ltd in the past has sold a solvent-free version of Universal Blue to Permatex in bulk, which they have repackaged as Permatex Hylomar HPF with our approval. This started at a point when Loctite (the former parent company of Permatex) was Hylomar?s US distributor. Since then Loctite was acquired by Henkel, which sold Permatex in a MBO, which was then acquired by ITW, and Hylomar has set up its own US distribution company. Some Permatex HPF may still be available in retail locations, but it is unclear how long stocks will last?.
http://www.hylomar.com/universal_blue_2.shtml
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 08-08-2007, 12:49 PM
G-force's Avatar
G-force G-force is offline
Do a search for Valco, they make (or repackage) Hylomar.
Mike Sumner
Castaic, Ca
Old 08-08-2007, 12:53 PM
dan's Avatar
dan dan is offline
Can EZ-Turn be found in your usual HD/Lowes stores, or do folks order it from ACS, etc?? Has anyone had mush use for Permatex Red Silicone RTV? Label says for high temp application.
EZ-Turn is available from Spruce (get the tube, not the can).
http://www.aircraftspruce.com/catalo...ezturnlube.php
And I used high-temp silicone RTV to seal the little gaps in the baffles, etc.
Dan Checkoway RV-7
Old 08-09-2007, 08:32 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default as for silicone
if the silicone has that rancid vinegar odor it will corrode alu. the ultra products by permatex do not. their old tried and tru blue is cheap and will corrode alu and they know it but like the rep told me here last fall it sells way to good to stop selling it.
some are called silicone some are called rtv. IIRC RTV simply means
room temperatur vulcanizing. many of the slicone will not stand up longer than a year (if that long) to oil and fuel.
fuel lube is a great product btw.
William Weesner/ still kicking.
Old 08-09-2007, 09:14 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Silicone is generally immune to oil but not to gasoline. Hylomar is considered a gasket dressing, not to be used without a gasket and Permatex does sell this.
I've had engines assembled with RTV silicone for over a decade, no leaks and most auto OEMs have used this in place of conventional gaskets for over 20 years. Very good with oil, very bad with fuel.
We use RTV for anti vibration in our electronics. I've seen no evidence of corrosion against bare aluminum in the last 14 years.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
