Closed Thread
Old 06-26-2012, 12:15 AM
drmax drmax is offline
Default 320 or 360
Hate to put this here, as to cause any ruckus but i'm eyeballing a 15 yr old 6A with a 150 HP O-320E2D 300 since major, fixed wood prop and a 8 month old 6A o-360A3A 300 since major, fixed wood prop. Both have the option for c/s prop, but tonight found out the 320 may have had some work done to the crankshaft, as in material removed thus making it impossible (as it is) to add a c/s prop. so it around 40K vs 55K and both panels basic vfr. I'm really on the fence here. I'm on 2100' paved runway with minor obstacles. Just unsure if it's worth the extra 15K for 30 more horses. (oh, well everything else being new, like the paint, tires, brakes, exhaust, nose gear, lighting, etc. I need to make a decision in about 2 wks. Any advice would be nice. (both sliders)
thx, DM
Oh and I put this here, for I'm basically questioning which eng would be best overall. Please move if this isn't the correct area.
Old 06-26-2012, 01:34 AM
gasman gasman is offline
30 hp more and over 14 years newer..................... pay the 55K and don't look back.
But, if your budget requires the 40k a/c then enjoy it.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 06-26-2012, 01:53 AM
RV6_flyer's Avatar
From someone that has been flying a 320 Constant Speed RV-6 for 2,600 hours and over almost 15-years, get the 360 and you will not look back.
The 360 is 10 pounds heaver and will burn less pounds of fuel per horsepower per hour than what the 320 does when both are flying at the same cruise airspeed.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-26-2012, 02:31 AM
Loman Loman is offline
Default O-320 - E2D has a solid crank - no CS prop
As far as I know, the E2D has a solid crank and was never capable of taking a hydraulic CS prop. An electric CS is the only option. So, it was not any modification to the crank that removed the CS possibility.
I would be delighted to be wrong as I have that precise engine waiting to go on the nose of my RV-9 and I would love to have a CS 'upgrade path'.
The presence or absence of a hollow crank is a minor matter compared to talk of material being removed from a crankshaft. That is what I would focus on.
Loman O'Byrne
RV9 TU. O-320-E2D. Engine hung, working on FWF, Arklow, Ireland
=VAF= dues paid through Dec 2020
Old 06-26-2012, 02:38 AM
WAM120RV WAM120RV is offline
Default Crank AD
Hi,
What you are saying about the crank on the 320 does not make sense.
The AD requires inspection for corrosion which can lead to cracking. If corrosion is found the internal bore of the crank can be honed to a max internal diameter of 1.91 inches, any more than this and Lycoming say its scrap.
If there is no corrosion, or if when honed it is corrosion free it should be magnafluxed and if no cracks it can be internally protected and stamped PID......its then good to go.
If it has been honed past 1.91, then you are really in the Experimental area. I wonder if it has any prop extension which would add more load to the flange even with a light wood prop. I would be asking some rather searching questions about this before making any offer on it, irrespective of the 320/360 debate.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 06-26-2012, 02:56 AM
Originally Posted by WAM120RV View Post
Hi,
yes, really unsure about this and unsure if i'm gonna go this route, now that you bring up the info you did. wish i could see the log books here, instead of them being 9 hrs away. i'll see what i can find out. on the budget end...it's all a finance job anway. I can manage this, just wasn't sure it was necessary. following the paper trail in wiki lycoming it's traced back to the
a1a with provisions for c/s prop. if i'm wrong on this, please someone else point this out. the O-360 was salvaged from a piper wreck. the runout mic'd .002. lycoming's rule is .003. so the engine was deemed serviceable. that's all i know on this. just going by what the fellers telling me.
Old 06-26-2012, 03:21 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default 320 vs 360
After owning a RV6 with a 320 and metal prop, I would get the 360. hands down.
Reasons:
- Re-sale
- Performance, yes it makes a nice difference
- Improves CG
- You will get your money back through better resale.
- Many buyers know to buy with an RV with a 360 after talking with a few owners as you are.
- I love my 360 w/CS in the RV7.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 06-26-2012, 06:22 AM
Mel's Avatar
Mel Mel is offline
The E2D does indeed have a hollow crank. However it is NOT compatible with a hydraulic constant speed prop because of the front bearing configuration.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-26-2012, 06:31 AM
thank you...process of illimation. you've helped!
Old 06-26-2012, 10:45 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Logs/Runout
If your seller has an iPhone, scanner, or somesuch, it's simple to copy the engine logs and send same to you.
If there was a prop strike or sudden stoppage the runout matters nada. Lyco says teardown necessary which is quite spendy. One I had which turned out OK was $3000+
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Closed Thread
