Originally Posted by RV_7A
Paul,
Absolutely do not trim this surface.
-Jeff
I totally disagree. It is not supplied in a final size and there is nothing difficult about trimming it and finishing it to a true/straight edge. 80 grit sandpaper glued to a 12" long sanding block wil do it in minutes
Install the cowl using the back plate as a reference. Then install the spinner (without the cowl in place).
Use the edge of the spinner backplate flange to mark a line around the inside of the spinner and trim to the line.
A side note... it is important that the spinner be installed with it fitting tight to the back plate. Otherwise you will be sucking it tight to the back plate with the screws. This will cause puckers in the spinner between the screws. This will just get worse with time.
Typically the front bulkhead holds the spinner a little to far fwd to allow it to fit the rear bulkhead tightly (primarily on a C.S. prop.) This can be corrected by grabbing the already mounted front bulkhead with your hands and pushing it aft slightly (grab at 3 & 9 Oclock and then 12 & 6 Oclock).
The bulkhead is made of soft aluminum and can be moved quite easily on a constant speed prop because it is supported by a small area on the prop hub dome so go easy and recheck the spinner fit often while you adjust.
