Old 06-23-2012, 09:43 AM
prkaye prkaye is offline
Default gascolator question
I have one of the big blue gascolators (Andair, I think?). When I was doing my annual I removed the quick drain. As I was trying to loosen the quickdrain (which was quite tight), I noticed the lower cylindrical portion of the gascolator was rotating inside the upper housing. I had to grip the lower cylindrical portion tightly to stop it from rotating so I could unscrew the quick drain from the bottom of it.
Question - is my gascolator OK?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 06-23-2012, 10:03 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Phil-
It sounds like you have Van's regular gascolator and yes, the bowl of the gascolator turns. In fact the whole bowl comes off (and needs to come off) to check the screen. That's what the four screws are for, to hold the bowl tightly up into the rest of the gascolator, but the bowl will still probably turn if wrenched on hard enough. Sounds like maybe you haven't checked your gascolator screen yet, so that should be something you look into. Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-23-2012, 11:04 AM
GeneL's Avatar
GeneL GeneL is offline
Default Van's Gascolator
Don't forget the early gascolators with 10 flats on cup was recalled by U.E.I.. If you have one call UEI @ (503) 992-0015. The new style has 12 flats. Gene
Old 06-23-2012, 11:35 AM
Default screen?
I have Vans blue Gas-5.
http://www.vansaircraft.com/cgi-bin/...ans-gascolator
Ok, I removed the bowl from the bottom, but I don't see a screen anywhere. How do I get to the screen to clean it?
EDIT-- DISREGARD, I found the screen. Thanks!
Phil
RV9A (SB)
Ottawa, Canada
