Unless you Navaid has a built in Smart Coupler you'll need one.
If there is a telephone type plug or wire out back of the Navaid you're set, otherwise:
http://www.porcine.com/
From Tru-Trak:
Garmin 295
The Garmin 295 requires a power/data cable (Garmin Part Number 010-10082-00) to provide data output. The Garmin 295
must be configured to provide the correct output to the autopilot.
Press the MENU key twice. Use the rocker keypad to select the ?INTERFACE? tab.
Press the down portion of the rocker keypad to select the ?FORMAT? field.
Press ENTER and a popup window will show the available settings.
Use the rocker keypad to select ?NMEA OUT? then press ENTER. Select 4800 for the baud rate.
Note: This is the baud rate that will need to be entered in the setup mode of the autopilot.
Now the Garmin 295 is correctly set up to provide the RS-232 serial output required by your TruTrak autopilot.
