Old 06-24-2006, 10:54 PM
szicree szicree is offline
Question Advice on wing root fairing
I'm fabricating wing root fairings for my 4 in the metal strip style (as opposed to the fiberglass fillet style) and I have a possibly stupid question: Is the fairing only attached at the wing root? I know there is a rubber gasket that slips between the fairing and the fuse side skin, but are there any fasteners there? It seems like, if not, the air would push the underside upward into the wing root gap. What's the deal?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 06-24-2006, 11:11 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Well Steve, that's the way they are on an -8 - they only attach to the wing, and float on the fuselage. Of course, on the bottom, they only go back as far as the spar, so there isn't much distance for them to get flexible and collapse upward. I think the fact that they are only a couple of inches wide makes the flexibility moot -the total deflection is just to small.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-25-2006, 03:28 AM
pierre smith's Avatar
Default Yes........
Hi Steve,
Paul's correct in that they only get attached to the wing. A tip from one who just did this.......be sure that the strips fit within a quarter of an inch of the fuselage so that the rubber bends upwards against the fuselage, sealing it tightly. They don't even need glue to hold them onto the trim strips with a close fit. I believe a tight fit helps your speed as well,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
