Should work just fine.
Another factor to consider is the deck height if the case is being resurfaced. As the case halves are fly-cut the cylinder decks are brought closer together and there's not a whole lot of room between the counterweights and the crankcase. This used to be one of the old ways to bump compression up before the different CR pistons that we now have today were available.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
