Old 06-19-2012, 10:35 AM
eison eison is offline
Default Aluminum composition question ASTM B 308?
I have a local supplier that I can buy some angle stock from that is 6061 T6 the same size as what came with the kit to replace a small departure from plans that I made.
My only issue is that the new angle is ASTM is B308, but the angle that Van's shipped is B221.
Buying locally will save days and multiple shipping $$$$.
I have googled the ASTM's, but frankly I am striking out. The metal supplier says that he doesn't think there is a big difference, but.....
Does anyone out there have any knowledge to share?
Eric Ison
RV 10 # 40764
Eric Ison
RV 10 Builder # 40764
N984ED reserved
Old 06-19-2012, 10:48 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
If the alloy (6061) and temper (T6) are correct and the dimensions and fillet radius are correct, I can't see what difference the ASTM number makes.
Thanks, BOb K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 06-19-2012, 11:08 AM
scsmith scsmith is offline
Default more specific?
It appears that the B221 specification covers a broad range of alloys and extrusion shapes and methods. It appears that the B308 specification is specific to 6061-T6 hot-extruded shapes.
So, it appears that you are OK.
I keep saying 'appears' because ASTM will only let me read the abstracts without subscribing (i.e. send money). But there seems to be enough information in the abstracts to infer what I said above.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
