06-17-2012, 06:15 PM
Flying tool kit
What have you found to be indispensable tools for a traveling/flying tool kit?
Also, what did you use to store/carry the tools?
I've got an Rv-10 that usually just has two passengers so weight and space are not as much of an issue.
Tom Hanaway
N518TP
40.15 hours (yippee-phase 1 done).
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
06-17-2012, 06:44 PM
Variety of lightweight tools.
Goody bag with an assortment of screws, wire, terminal ends, a few lenghts of safety wire, nuts, bolts, washers, 2 brake puck gaskets
Of course, duct tape, weldon epoxy
glo-nights sicks, small led flashlight, mylar space blanket & a poncho
Not in my tool kit, but I also carry a bag with a couple bottles of water & propel, power bars, cliff bars...
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
06-17-2012, 10:51 PM
Extra tube for tires, some sort of jacking mechanism for the airplane, and a pump to inflate the tube.
I also carry a couple spare spark plugs plus wrench. And when flying in remote areas, some survival equipment.
I got two Bison Bags that fit behind the seats in the RV-9, but your space in a 10 may be different size/shape.
Greg
Greg Arehart
N 7965A
06-17-2012, 11:38 PM
Senior Curmudgeon
Greg
FYI, the Bison bags are correctly shaped for a 10, and there is room enough for 3 of them to fit across the baggage area, if you do not stuff them till they bulge.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
06-17-2012, 11:46 PM
For your RV-10, an extra set of brake pads - they are not a common type.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-18-2012, 04:24 AM
Electronic manuals stored on your iPad.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
06-18-2012, 06:55 AM
CO2 4 air pump
I keep a spare tube but use the little Co2 cartriages and the little adapter from a motorcyle shop to air it up. Small and compact.
06-18-2012, 05:52 PM
Not exactly a "tool" but I just learned this trick this past weekend - a spare GAS CAP!!
JD
RV-4 - 160HP O-320 - Sensenich GA
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
06-18-2012, 06:35 PM
Oh, yeah, along with the spare fuel cap, also a spare fuel drain with (new) o-ring in place. Easy to change wet, though you might lose a cup of fuel.
Greg
Greg Arehart
N 7965A
06-18-2012, 06:56 PM
ACME lip extension tool. So you can kiss your *** goodbye if things go really bad.
Actual repeat offender.
