Old 06-17-2012, 01:45 AM
Sig600 Sig600 is offline
Default Duckworks LED Landing lights
Just found these on the Duckworks site last night. Anyone tried these out yet?
http://duckworksav.com/WTLightKits.html
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 06-18-2012, 11:07 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Default Duckworks LED lights
I've been flying the prototype Duckworks LED wingtip lights for just over a year. I have a 3 position switch for my lights, OFF; WIG/WAG; LANDING. I WIG/WAG the Duckworks LEDs and for landing the Duckworks LEDs are on steady AND I have a pair of Duckworks HID in the leading edges of the wings. The LEDs have been on either WIG/WAG or steady for all of my flights.
The LEDs project a bright focused beam. The HID's are BRIGHT and a bit wider beam. The LEDs will illuminate the blue taxi reflectors the complete distance at Independence (7S5) which is 3100+ feet.
The Hillsboro Tower has commented how visible my plane is WIG/WAGging the LED's. I'll try to take some pictures in the next few days and post them.
(Note: Don of Duckworks is a long time friend. He was primary TC for my CH601HDS. I have no financial interest in Duckworks.)
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
Old 06-19-2012, 12:27 AM
Awesome. I've convinced the majority share holder in this build to go with these, he wants AeroLED position/tail lights. Should all make for a nice combination.
How hard is the install? My only worry is once you glass in the mounts in the tips, looks like you're pretty much stuck with the angle.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 06-19-2012, 08:57 AM
Richard@Langair Richard@Langair is offline
Thanks for the Pirep Roy!! Don and I appreciate it.
The LED lights are not aim-able once installed, but there is some guidance to get them lined up mostly straight in the instructions that are included with the kit.
As a side note, these are just as easily installed in any fiberglass surface with enough real estate to mount them as they are in the wingtips they are being marketed for. They only need about a 2.5 inch diameter circle to mount in!! Cowls, Wheel pants, wingtips, pretty much any forward facing surface.
Richard Squires
Old 12-07-2013, 08:14 PM
mvidalr's Avatar
mvidalr mvidalr is offline
Lightbulb wire
hello,
what would be the best wire gauge for a set of Duckworks Round WingTip LED lights (one per wingtip)?
Also, shielded/unshielded?
thanks
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
