The upper spark plugs on the #1&2 cylinder are really really close to the cowling. I currently have high altitude sparkplug wires connected to champion RHM38E plugs. The wire insulators have a 3/4" diameter nut, which limits the type of plug I can install. I understand there are shorter plugs available in the 5'8" diameter. My question is are there shorter 3/4" diameter plugs out there or can I somehow reconfigure the wires to fit a 5/8" plug?
Thanks for the help!
Rob Holmes www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
