Originally Posted by mannanj
Jim:
I had some scrap 1/8th thick mild steel strap laying around the hangar. It was about 1/2 in. wide so I cut off 2 pieces about 1 in. longer than the rudder horn. I spaced it with the tab ends equidistant fore and aft over the rudder horn, then drilled 4 holes. Two to fit the holes in the rudder horn for AN-3 bolts, and one in either end. On the forward end you attatch the rudder cable fork. on the aft end you can either use an eye-bolt or just put the spring ends there. If it wears, it's easy to replace and you're not sacrificing the aluminum material in your rudder horn.
Hope this helps.
We must think alike. I am 1/2 done doing exactly what you describe. I had
some 1/8 inch 4130 and milled a 1/2 inch wide piece and have one side
drilled so far. My tailwheel springs attach with those clips so I am going to
drill that end only 1/8" and see in the clip will go thru. I will post a photo
when I get done.
Jim Miller
