06-13-2012, 08:47 PM
Use of 600 x 6 Mains on RV-7
Has anyone ever used Cleveland wheels and brakes using 600 x 6 mains. I have a good opportunity to acquire some and dont know if they will work? ideas???
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
06-14-2012, 02:11 AM
Allow for axle size increase needed. And use caution. The brakes were designed for 2500# aircraft. You could easily tip your 7 on it's nose with enough pressure applied.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
06-14-2012, 08:57 AM
Probably not the best idea.
The additional mass and moment of inertia will increase the likelihood of shimmy and vibration of the landing gear. Also the wheel pants won't fit.
So let's see - more weight, more work, a landing gear vibration problem, more drag from the larger pants.....
Dave
06-14-2012, 10:44 AM
The answer is yes, it has been done. But I would only do it if my landing conditions required it. Not needed for normal operations. It will add weight, but that's about it.
06-14-2012, 01:04 PM
This has been done on a few RV-9's that I know of. It takes custom gear legs with longer axles. These are about the same cost as the standard legs. Bigger wheels, tires, ar needed. Tipping over doesn't seem to be an issue.
Contact Van's for details.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-14-2012, 02:53 PM
Larger wheels on RV7A
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
06-14-2012, 11:06 PM
thanks too all
Thanks to all i have decided to use standard tires and wheels , thanks again
Originally Posted by Bevan
Dave Cobb
Wings complete
