Old 06-13-2012, 06:45 AM
Smilin' Jack Smilin' Jack is offline
Default Brake reservoir sealant ?
What do you folks use as a sealant on the nylon fitting that goes into the brake reservior.
thanks
Smilin' Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 06-13-2012, 12:17 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Permatex #3 "Aviation Form-a-Gasket". The non-hardening brown goo stuff in the bottle with the brush in the lid.
It's a great general-purpose thread and fitting sealer for just about anything on an airplane that carries gasoline, oil, or hydraulic fluids. Just don;t get any inside the brake line/fitting itself.
Neal Howard
Airplaneless once again...
Old 06-13-2012, 05:48 PM
Walt's Avatar
Walt Walt is offline
I likeTite Seal gasket and joint sealing compound, use it all the time.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
