Old 06-12-2012, 11:00 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default flame test standard for fabrics
Can anyone point me to any standards that exists re: how long aircraft fabric must withstand an open flame before catching flame itself?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-12-2012, 12:06 PM
DanH's Avatar
DanH DanH is offline
http://www.tc.faa.gov/its/worldpac/techrpt/ar00-12.pdf
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-13-2012, 12:49 PM
flyboy1963's Avatar
Default comfort level?
this was by no means an exhaustive study, but when I was buying some upholstery, I found that almost everything automotive fabric I ran across was 'fire-rated' which only meant that it would not support combustion, which may or may not be the same as 'self-extinguishing'. ( wool?)
If you're not happy with that, you can obviously hold a match or torch to it like Dan does...it's kinda fun, and an eye-opener when you see that black smoke come off of some of the fibres, and imagine the cockpit full of that junk!
I also sprayed all my existing seat cushions, carpets etc. with 'Flame-Out' from ACS I think....which made me wonder, if you Scotch-guard your fabric, does that make it MORE flammable?
http://www.aircraftspruce.ca/catalog...ectashield.php
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 06-13-2012, 08:37 PM
billnaz's Avatar
billnaz billnaz is offline
Default Flame spread applicability
The benefit of slow flame spread is realized when the flame is over there, and you are here, so to speak. When the flame is impinging on the cabin walls or the seat you are sitting on you've got a much bigger problem which will not be lessened by a slowly advancing flame or self extiguishing fabric. There is also a lot of concern these days about the risk of long term low level exposure to flame retardent chemicals. I'm not worried about the flamability of the interior fabrics in my plane. But that's just me.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
