Originally Posted by ExtraKatana
What is the procedure to getting to the Van's Parking area? Does parking sign need to be HBP? GAC? GAP?
I don't want to be over by the Hilton again like when I had another type of plane.
Thanks in advance
Just have the HBP or HBC sign and you'll be directed to the correct location. They do separate homebuilts by type, but sometimes they run out of room towards the middle of the week and mix things up a bit.
If you use a GA sign, you'll most likely end up in the north 40 again.
