Old 06-11-2012, 04:13 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Default Main Wheels - Valve stem crooked
I've been putting my tubes, tires, and wheels together. The documentation for this task is really weak. I'm still trying to figure out how the brake calipers are held on. But meanwhile, the valve stem sticking out of the wheel is crooked. Is this a common problem? How do I fix it?
Here's what the tube looks like. The instructions tell you to remove the washer and nut at the base of the tube, next to the rubber, and discard them. I did it both ways, and mounted the tire on the wheel and inflated it, and it didn't make any difference. It's still crooked, either way.
Here's the inflated tire on the wheel. Is this normal? This just seems unacceptable to me. But I'm afraid to start bending things before checking with those more knowledgeable.
Do I modify this? If so, how is it best done? Thanks in advance for help and comments.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 06-11-2012, 04:18 PM
Walt's Avatar
Walt Walt is offline
Good to go, that's the way it is.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-11-2012, 06:51 PM
bhester's Avatar
bhester bhester is offline
Thumbs up
They use to make the stems different and they stuck straight out like they should, they have changed the design and now they bend over and touch the edge of the rim when you inflate them. I use to have a picture of both but can't find them. this drawing shows the difference.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 06-11-2012, 06:59 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Are they new Aero Classic Leakguard tubes? My new ones did the same thing with Cleveland wheels....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-11-2012, 08:12 PM
scard's Avatar
scard scard is offline
I agree, it sure sucks. Par.
Scott Card
CMW E-Lift
Old 06-11-2012, 09:21 PM
Scott Hersha Scott Hersha is offline
I have new air stop tubes and they do the same thing. I think they are all like that now. I put a nut and washer on the inside it try to 're-align' it a little and it helped. No leaks after 200+ hours. They don't fit the rims like they should though.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 06-12-2012, 12:22 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
We had one that was reeeealy bad. Vans sent us a new one...
Now both look like yours.
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 06-12-2012, 05:24 AM
BSwayze's Avatar
Gentlemen, thank you for these responses! I've learned some things. Wow. I'm quite surprised, actually. However, I'll leave it as is and build on. I don't like the way it looks, but it sounds like there are no worries.
Gil, yes. These are the Aero Classic Leakguard tubes, came in the kit. Made in Mexico! Interesting that the Aero Classic tires are made here in the U.S.A., though.
Even though Vans says I should remove and discard the nut and washer at the base of the valve stem, Matco says to leave them on. So what do you do? I'm going to leave them on. They make this stuff, after all, and perhaps Vans hasn't updated the manual since switching over from Cleveland. ??? Anyway, thanks again!
Bruce Swayze
Old 06-12-2012, 07:04 AM
novipilot novipilot is offline
Did you use tire talc on the tube? After that, inflate the tube in the tire just a bit to seat it, but leave the valve out of the stem. Then you can maneuver the tube a little to get things aligned. Re-insert the valve in the stem and inflate.
Old 06-12-2012, 10:19 AM
Steve Steve is offline
Isn't there supposed to be a grommet in the wheel where the valve stem pokes through?
Five Sierra Fox
RV-9A
Utah
