From Emagair website (makers of the Emag & Pmag):
Auto Spark Plug Adapters - Plug adapters permit the use
of 14mm automotive type plugs with a ¾” reach. [Not
tested with engines that use long-reach (13/16”) aircraft
plugs.] First, install adapters with the supplied gasket on
the spark plugs finger tight. Then, insert the combined
assembly (plug with adapter) in the engine and tighten to
18 ft/lb (standard auto plug torque).
Note 1: If you install and torque the adapters separately, stresses will be
focused at the adapter neck and can cause it to fail during installation.
http://www.emagair.com/Manual%20LC114v20.pdf (Page 11)
Actually they don't mean 18ft/lb. That's not a torque. They intended to say 18 ft*lb. But you get the idea....
