Harbor Freight has
cheap mover's dollies for $7.99 (with a coupon) that I modified to easily move the airplane around the garage. They're rated at 1000lbs and are just the right size for our wheels.
Cut a notch in the 2x4 where the wheels sit and scallop the corners so the wheels can pivot. Position so the wheels will rest equally on the notched 2x4s and the two end pieces. Deck screws attach the 2x4s to the bottom. Fifteen minutes and they work great, especially for $7.99 each!
