Originally Posted by tacaruth
For those flying with Ztron Nav/Strobe lights, are you experiencing any radio interference problems? There is a post on their own forum that lists this as a problem. Any experience worth sharing about these lights would be appreciated. I am looking at replacing my Whelen HDACF system using the same wiring which is not shielded.
Tom RV-7A Flying
That was probably me that posted on there forum.
I had the 24V early version units and had problems with RFI in the Com and Nav radios to the point of making both not usable. (RFI was greater than communications radio level)
I returned them and they replaced them with the 12V "New" version that has no switching power supplies in them.
Now they are quiet as a mouse. (no interferance) in fact the right wing has a wingtip nav antenna in it within 6in. of the nav/strobe light and I cannot detect any noise level change at all in the nav (or com for that matter) when switching them on to off and back on.
Also to note: I did NOT install sheilded wire for the power wire to them. Probably would do it if I were building again but never the less it is not a problem.
I would guess with the "older" version the RFI could be filtered out and that would be better (less current drain with the switching power supply) but I did not want/feel like expermenting at the time.
