Old 06-05-2012, 07:36 PM
Cfrisella's Avatar
Cfrisella Cfrisella is offline
Default Oil cooler NACA installed
I decided to mount the 4 inch NACA on my 7A to see how it performs and also give others an alternative mounting method. I'm sure it's been done before but it worked out well with little fabrication required. Hopefully it will be ready to fly over the weekend and I can get some numbers to share. My engine engine/oil temps weren't running really hot but I figured since I'm making this stuff I might as well be testing it too. Temps here are high so it will be interesting. If you're interested in any of the carbon componets they're available through bonehead composites.
Chris Frisella
Www.boneheadcomposites.com
Old 06-05-2012, 08:06 PM
N427EF N427EF is offline
Interesting concept.
I hope your efforts pay off but that area of the cowling is generally very low pressure and not ideal for a NACA inlet.
I am looking forward to hearing your results and hope you can prove me wrong.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
