Old 06-04-2012, 05:53 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default mineral spirits on plexi?
Is if ok to use mineral spirits on thr plexiglass to clean.?
By the way do not use thread locker on fiberglass screws..
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 06-04-2012, 06:00 PM
Lars Lars is offline
I'll bet you get a bazillion opinions on this one
I've used it many times without issue on acrylic motorcycle windscreens (think stressed, formed plastic) to remove tar. These days I stick with denatured alcohol. Less oily/stinky and has no issues either.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 06-04-2012, 06:27 PM
Did you get micro cracks? I got.
Old 06-04-2012, 08:39 PM
miyu1975's Avatar
Vlad, yes..I did, within hours. Per vans I removed the plexi glass and cleaned off thread locker residue, and reinstalled....and to not get the screws to tight. The spider cracks are still there, one day to only get worse I assume. Think I can order the rear piece of plexi only?..this for a tip up.
Ryan Allen, CFII
E-170/175
Old 06-04-2012, 09:22 PM
ArVeeNiner's Avatar
What Van's says about cleaning Plexi as well as other tips:
http://vansaircraft.com/pdf/Acrylic_...ndow_Hints.pdf
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 06-04-2012, 11:34 PM
dav1111 dav1111 is offline
Super Moderator
I would recommend Todd's Canopies for replacement.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 06-05-2012, 07:15 AM
No, they will not propagate. It's really a funny phenomenon. Spider cracks appeared overnight after I screwed the rear window to the roll bar with locktite. It was two years before first flight. They are the same now after several hundred hours of vibration. There is other interesting thing going on with tip up canopy. You can only notice it after you start flying and put some hours on it. On mine there a white powdery spot appeared in place where plexiglass touches roll bar. First I just wiped the spot and thought it was some foreign substance. Then it appeared again. And again in couple weeks. Then I could feel and see little worn indentation in plexi. I will get picture in couple days. I don't have rubber channel installed.
Old 06-05-2012, 12:26 PM
flyboy1963's Avatar
Default go with the manufacturer's recommendation!
there's a lot of well-intentioned info on here, and the internet....but use at your own risk!
I've used mineral spirits for 28 years on plexi, and never seen any adverse effect. But that doesn't mean, if you buy some hardware store paint thinner that happens to have some toluol in it, and you let it stand on your plexi for a week, that it won't etch the surface!
http://www.aristechacrylics.com/site...es/tb013_0.pdf
above is an example of a manufacturer's recommendation....which appears to limit the cleaning solvents to Isopropyl alcohol, naptha, and methanol ( exactly what concentrations etc. isn't explicit).
stronger solvents are allowable for painting, as they ensure a good bond, and are INTENDED to etch or chemically bond, then flash off, without detrimental effects.
Van's tips are good, and I always like to remind folks that the exposed edge is about 10 times more subject to damage from solvents, the acetic acids in silicone ( loctite?) than the face.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 06-05-2012, 01:23 PM
gear1 gear1 is offline
Default Solvents for cleaning plexiglas
When he was helping me install the new canopy on N5678C, Jay Pratt used acetone for cleaning overspray from the polished acrylic surface. I was amazed. There was some overspray from the final paint, too, and it wiped right off with acetone! I would not have believed it if it had not been Jay that demonstrated it!
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 06-05-2012, 01:39 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Again, go with a reputable manufacture's notes...
If you have to remove masking tape residue or other sticky or greasy stuff, the safest solvents are 100% mineral spirits or kerosene. Some alcohols are safe, such as isopropyl alcohol, but not all.
From LP Aero...
http://www.lpaero.com/CAREINS.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
