Old 06-04-2012, 01:01 PM
redhawk redhawk is offline
Default Air Fuel Oxygen Sensor
I had a RV4 with a air fuel sensor gauge in it that worked wonders for precisely leaning the engine. It is no longer produced and was looking for recommendations of any good brand available that may be compatible with leaded avgas?
Thanks out there...
Old 06-04-2012, 01:31 PM
YellerDaisy's Avatar
YellerDaisy YellerDaisy is offline
Hi RedHawk,
As far as I am aware, there are no oxygen sensors that are compatible with lead.
However; O2 sensors will work "for a while" in a leaded environment. I've heard of people locating them in cross-over pipes and significantly increasing their life. I have no facts to back to this up but believe the numbers that I've heard are something around ten hours up to as much as 25 hours. The wide-band sensors are far to expensive to replace that often but the single-wire sensors are almost cheap enough ($20-ish) to do that if you could get 25 hours out of them (ignoring that it would be a nuisance maintenance item).
JD
RV-4 - 160HP O-320 - Sensenich GA
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
Old 06-04-2012, 03:39 PM
kbehrent's Avatar
kbehrent kbehrent is offline
I currently have 50+ hrs tach time on a LC-1 wide band o2 sensor from Innovate Motorsport and it's still working just fine. The replacement sensor will cost you @$80.
I am using Precision's Eagle EMS which is their silverhawk on steroids! It consists of dual electronic ignitions and electronic fuel injection. It's basically a mini fadec system without a prop controller, which is the way I like it!
The Eagles does not use the O2 sensor, but you can use one to verify the results and tweak your settings to achieve the desired results.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 06-04-2012, 05:22 PM
Default O2 sensor gauge
Hi all,
It took me all day but I finally found the one I had before at "Summit Racing".
It's a "Cyberdyne 7009" for $36, and uses a standard Bosch sensor that screws into a nut welded onto the exhaust.
This setup worked great in my RV4 for leaning my mixture, and never had any issues with leaded Avgas hurting its performance.
It's going on my RV8 !
Old 03-24-2013, 11:52 AM
gasman gasman is offline
Update....... http://www.glowshiftdirect.com/red-d...and-gauge.aspx
Keep in mind that you will have problems with lead contamination.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-24-2013, 03:39 PM
eddieseve eddieseve is offline
Hi Guys,
From an information perspective how do you use the gauge and what indications are you looking for when you lean the engine?
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
