Old 06-04-2012, 10:26 AM
cb02740 cb02740 is offline
Default Pitot Tube installation
Hello,
i have a few considerations concerning the pitot tube installation. Either i will install the original Vans pitot tube or that one from Dynon.
-What is the best place to install the dynon pitot tube with AOA indicator?
-I think it is a good solution to install the pitot tube on one of the W-802PP access plates. Are these plates strong enough?
Is it better to install the pitot tube on the access plate for the stall warner? The problem is to lay the two lines through the main spar.
-Photos would be very helpful.
Best wishes
cb
Old 06-04-2012, 11:36 AM
HSANTIBANEZ HSANTIBANEZ is offline
Default tie down clearence
Hi, you can use the specified place but i got one station far away to have more clearence with the tie down.
Hern?n Santib??ez
Valpara?so, Chile
RV-7 TMX-IO-360 G3X and VPX Flying over Chile
2018 Dues Paid
Old 06-05-2012, 01:00 PM
Thank you for your answer.
Do you have any photos of your pitot tube installation?
Best wishes
cb
Old 09-27-2012, 04:31 PM
southtarnation's Avatar
southtarnation southtarnation is offline
Bump for pictures id like to see too please.
Jesse
'89 RV-4, N2626C - purchased flying
Converted to Fastback - Sliding Canopy - Tall Gear
Dynon Skyview w/ acc. & VP-x Sport
Catto 3-Blade (gen. 1)
Based: KPGD
Old 09-28-2012, 12:02 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Where the directions say to put it...
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 10-09-2012, 09:41 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
I put mine in the exact location as shown on the plans; and here's how i did it.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 10-12-2012, 03:53 AM
Andrew Griffin Andrew Griffin is offline
Very nice work Derek. Thanks for sharing your pictures.
I notice you didn't prime the threaded rod end bearing on the larger of the aileron pushrods. I was under the impression that it is pure aluminium & needed to be primed. In my -8 manual it mentions this specifically for the elevator pushrod threaded rod end bearing but not the aileron pushrod threaded rod end bearing. I primed mine just in case and only because I stumbled on this part in the fuselage section before riveteing my aileron pushrods. Does anyone else have any thoughts on this?
Regards,
Andy Griffin
rv8andy@gmail.com
RV-8 QB under construction.
