Old 06-04-2012, 10:02 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default First engine start - 13 PSI Fuel pressure
Had first engine start yesterday that went really well. My Dynon Skyview was showing 13 PSI pretty much the whole time, with or without the booster pump. The carbureted O-320 engine ran just fine. Wonder why the high fuel pressure indication? Thanks for any suggestions.
Thanks to Tom, James and Ken for mulling over my FWF this past few weeks leading up to engine start. Thanks to Steve for video taping the start. And Scott, Ron for the moral support! Was a great day!
http://youtu.be/1S6FWLT_CYg
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-04-2012, 01:22 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Is there a calibration element to fuel PSI? Perhaps a scaling factor (eg 2x) that is set incorrectly?
If not then do you have a way to verify input pressure (known source) against indicated pressure?
Old 06-05-2012, 07:27 AM
Mike nice to see it alive! Your online resource was tremendous help for me. When I started building my plane your website was bookmarked and I used it extensively. With sites of Scott Card, Jerry Thorne and Mike Shipper.
Don't stop now. Wipe that spot James pointed and go up!
Old 06-05-2012, 11:23 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Good job, Mike! Your site was one of those that was very helpful to me early in my build so it's nice to see you at this stage too.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-05-2012, 12:54 PM
Great to hear Mike---another RV in SC!
Tom
Ridgeland, SC
Old 06-05-2012, 02:31 PM
mike newall's Avatar
mike newall mike newall is offline
Go into Dynon set up - you are on the wrong code for the fuel pressure.
Had the same problem on ours.
Can't remember the exact setting - had to read the instructions but it worked
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 06-06-2012, 04:36 AM
Don's Avatar
Don Don is offline
Default Congratulations
Good job Mike!
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 06-06-2012, 05:57 AM
mikehoover's Avatar
I checked my Dynon Skyview settings for the fuel pressure sensor and the default was the 0-80 PSI sensor (100-411-001) that would be used for injected engines. I changed it to the 0-30 PSI sensor (100411-000) that is used for carbureted engines and the fuel pressure now shows between 4 and 5 PSI. Thanks for the suggestions and kind comments! Can't wait to fly this thing!
Mike Hoover
Columbia, SC
www.eaa242.org/
