06-03-2012, 06:44 AM
Mazda 13B Progress in 9A
I finally made some progress on my engine yesterday when a buddy came out and TIGed up my exhaust manifold. Will need to add some external bracing to help carry the load (w/the manifold) and turn it down with to 90 degree pieces and run it down the middle of the fuselage to a muffler (type TBD).
Doug Lomheim
OK City, OK
RV9A #116
06-03-2012, 07:12 AM
VAF Moderator / Line Boy
Slow but steady progress Doug - slow but steady! Maybe you need to sneak up to OSH this year to get fired up - we'd love to see you there.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
06-03-2012, 07:38 AM
Good to see you are still progressing Doug. It's a long grind to do something like this.
What material and wall thickness are you using for the exhaust here?
06-03-2012, 05:53 PM
Looks good! You should be getting close to an engine start.
My friend Ed Anderson placed his exhaust ports straight down on his -6A to make installing the exhaust easier.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-03-2012, 09:45 PM
Exhaust Progress
Ross: I should have known that question would come up, and I should know the answer right off the bat; but I bought the pieces about five years ago and I've slept since then! I'll look tomorrow at my receipts, but it's definitely overkill on the wall thickness and therefore the weight. I think it was something like .115??? and 304 stainless as used by some guys from our Rotary Newsgroup who have been flying for a number of years without issues. I am sort of viewing this a way to get off the ground with a very robust system that I won't have to mess with for a while; but with the expectation of fabricating a better and lighter system in the future...
Doug
06-03-2012, 09:47 PM
Ed Anderson Plugs Up
Originally Posted by N941WR
Looks good! You should be getting close to an engine start. My friend Ed Anderson placed his exhaust ports straight down on his -6A to make installing the exhaust easier.
Bill: I have seen Ed's RV-6 at numerous Alternative Engine get togethers and his method really does make the exhaust installation a lot easier!
Doug
06-03-2012, 10:25 PM
Doug it's time to wrap it up and go flying. Do you see how many 9s are recently completed? Pick up the speed I love First Flight Parties.
06-04-2012, 05:19 AM
Friend of mine ran a 13B in an RV6 for 350 Hrs. Best radiator setup was two air conditioning radiators installed in series one in each inlet, standard cowl.
06-04-2012, 10:11 AM
Well, to be fair, he did get in .8 hours with me on Saturday before welding the exhaust mentioned above.
06-05-2012, 08:02 PM
Exhaust Material and Wall Thickness
...What material and wall thickness are you using for the exhaust here?
I found the web site for the Wagner handrails and it is 304 Stainless Steel and .120 thickness...
Doug
