Old 05-31-2012, 05:03 AM
Clouddancer Clouddancer is offline
Default Spring Aileron Trim and Stick Pressure
I wondered if there is anybody who has flown his RV with and without the Vans spring aileron trim system? Is there any difference in stick pressure in flight with the added springs? I can imagine that the the feel might not be so light any more.
I'm building an RV-4 without autopilot. Is an aileron trim recommended or is it only a nice-to-have?
You may have noticed that I'm struggling to decide if I should incorporate a an aileron trim or not. It would be a spring based system, as I have no trim tab on the aileron.
Andreas Uebersax
RV-4 SN2416 in slow progress
Switzerland
VAF donation 2019/12/13
Old 05-31-2012, 05:13 AM
N208ET N208ET is offline
Default On my 8A
I have flown without my aileron trim hooked up during flight testing. I had a heavy wing so I disconnected the trim during the fix to make sure I was just fixing the heavy wing problem without any interference from the trim system, seems like a good idea to me. In reguards to flying without aileron trim, that would not be for me. Fuel burn is going to affect roll trim, I like to keep my plane in trim as much as I can. Maybe it is just the way I fly but I am constantly playing with my trim after changes in power settings, wouldn't like flying without it.
Randy
8A
Old 05-31-2012, 05:14 AM
rvator_md rvator_md is offline
I didn't install the aileron trim before the first flights. I guess my thought was to see how the plane flew without it. (ie: heavy wing) During phase 1, I installed it, because I knew I was going to be flying long cross countries and the trim would help with the fuel imbalance. Van was right, it does.
Mike Rollison
RV-6 N512RS
KDMW
Mid-Atlantic RV Wing
Old 05-31-2012, 05:44 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I liked the spring aileron trim and did not notice any change in stick force to use it. One mistake I made when I originally installed it was to stretch the springs out and I had a lot of tension on them. Later before I finished construction on the plane, I added safety wire loops to the springs to relieve the tension. I set the system up so there was very little tension on the springs when in neutral and the sticks were barely held vertical when in neutral. Changing the position of the lever would induce enough force on the sticks to move them and trim the plane. Not much force is needed to trim.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 05-31-2012, 05:46 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I installed one in my RV-4. It is very useful for cross country to account for fuel burn. I flew for about 10 hours before installing it. There is a SLIGHT difference in control feel from the springs, mostly in roll, but also a bit in pitch.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-31-2012, 05:49 AM
Pat Stewart Pat Stewart is offline
I never connect the springs during initial flight testing. I want to see how she flies and make sure the springs are not part of a possible heavy wing indication.
Pat
Old 05-31-2012, 06:09 AM
DanH's Avatar
DanH DanH is offline
I didn't install any aileron trim, don't miss it, and don't find fuel balance to be an issue.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-31-2012, 06:20 AM
I've disconnected my system for first flight and, frankly, I'm wondering why I installed it in the first place. Given the very minute stick force necessary to effect change and assuming proper fuel tank management, is it necessary? I guess I'll find out.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-31-2012, 06:53 AM
Walt's Avatar
Walt Walt is offline
I'm with Dan on this one, installed the mechanism during the build but removed the springs for flight test, never felt the need to re-install.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-31-2012, 06:59 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
For my 6, I installed the servo operated trim tab method. I do not like bias springs.... period. Even though required pressure to keep level is light, I really enjoy keeping the 6 in perfect trim with just a touch on the hat switch button.
L.Adamson
