My hangar is 60 X 72 Morton building 14' walls. All white inside, it has 5 trusses. I put 3 F96T12CWHOs on each truss, each bank of lights/truss is on it's own switch I forget how it's all breakered. There's some receps on the 20amp breakers with some of the lights. IIRC the lights pull about 3.5 amps ea. So I just loaded it accordingly. All my wiring is in conduit, & my gas and air is steel pipe.
I'm a licensed electrician/plumber so I figured I'd just as well do it right the first time.
BTW, the T12's were the norm when I did mine.
