Grounding Shielded Cable-Strobes
I have a Whelen strobe set up with a single power supply. The interconnect cables are shielded and since I understand that shielded wire needs to have the shield grounded out, I was thinking about simply grounding them out to the base of the power supply (which of course is mounted to the fuselage). Does this sound right?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
