I pro-sealed the trailing edge, while clecoed to a fairly thick walled aluminum square bar, let it sit for a couple of days. It came out very straight. I back riveted every tenth rivet or so like the instructions say, but just enough to set them. Then I added rivets in between, again setting them a little bit. I took my time setting the rivets, each a little at a time, and all from the same side. It never showed any sign of bending, and ended perfectly straight. I think the pro- seal pretty much prevents any movement, and I had the gun turned down pretty low, you dont need very much pressure for back riveting.
Damon Wack
RV-7 in progress
