Old 05-29-2012, 12:22 PM
cjensen's Avatar
cjensen cjensen is offline
Default Removing a prop spacer...best method?
I'm having one heck of a time removing the prop spacer from my 290. Thoughts on best method???
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 05-29-2012, 01:17 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Do you plan to re-use the spacer???
If it is not going to be re-used, can you drill a couple holes in it, tap the holes, and use a couple of bolts to jack the spacer away from the crank flange?
Or, bolt a lever on the spacer, and rock/work it off?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-29-2012, 01:40 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Mine is also difficult to remove on my O-360. I hold a piece of 1 x 2 pine against the back of the flange and gently tap it with a hammer. It usually takes working around the flange a couple of times to get it loose enough that I can pull it off.
Reinstalling it I gently tap from the front, again with the wood.
Hope this helps.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-29-2012, 01:54 PM
cjensen's Avatar
Definitely want to reuse it.
Chad Jensen
Old 05-29-2012, 09:15 PM
cjensen's Avatar
Rather than a board, I bolted a piece of steel angle to the flange and I'm tapping it off side to side. Slow going, but it's working.
Chad Jensen
