Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-29-2012, 11:36 AM
Michael Henning Michael Henning is offline
Default Not enough travel on Jirosti(?) governor
My cable from Vans has a 2" stroke, which isn't enough to get me to low rpm stop on governor. The DJM throttle quadrant isn't running out of travel, the cable is.
Any thoughts?
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-29-2012, 11:41 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Sounds like you may have to relocate the governor arm.
Are you getting full RPM???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-29-2012, 12:10 PM
I do have full rpm. I was just thinking that I want to check with the prop control full forward that I am indeed at the extreme travel of the cable (ie- that I am hitting the end of the cable and not the end of the quadrant first.).
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-29-2012, 01:11 PM
Bastien's Avatar
Bastien Bastien is offline
Hello Michael,
I also have the same problem which my Jihostroj governor. I have the full RPM position and I can't pull the DJM prop control enough to have the "max pitch" position (1/10inch missing). I believe this won't be a problem as we never fly with the prop control full aft (maybe I'm wrong but on the other airplanes I flown, it was like that).
If I recall correct, in my case I could have drill an other hole in the lever to reach both extreme position on the governor but the two holes would have been too close and so I didn't do it.
Have a good day
Van's RV8 3040 F-PVRB
Aerosport IO-375 turning WW200RV
Dual Dynon SV1000
SJ Wheel pants/plenum/cowl
Flying since 07/27/12
Old 05-29-2012, 01:14 PM
rocketbob's Avatar
I had the same problem on my rocket since the governor I have is a Jijostroj. I talked to the people who make the PCU-5000 governor (made by Jijostroj) and they told me not to worry about it as the last portion of the governor arm travel did not actually reduce RPM's measurably past half travel.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-30-2012, 09:38 AM
RVjim's Avatar
RVjim RVjim is offline
Default symptom vs problem
This is what I saw you write.
The symptom is the governor arm doesn't move full range.
The problem is the cable travel is too short (2").
The solution could be a new cable (same length) with a longer travel.
(Been there, done that.)
Jim Ayers
Just my thoughts
Old 05-30-2012, 10:49 AM
I was thinking of a longer cable too, but there are the associated mounting length differences.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-30-2012, 02:33 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Don't worry about it.
You never use the extreme low RPM range.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 06-26-2012, 11:56 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Adding to Smokey's post, it is in the Vans Governor instructions that you will not reach both stops.
Clearly important that you easily reach the Max RPM position i.e. ensure the Prop Lever is not hitting the Quadrant etc. with a reasonable margin.
I doubt you will ever use the second half of the range of travel, unless you really are into cruise / low RPM descents
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
