Old 05-28-2012, 09:38 PM
eddieseve eddieseve is offline
Question Bogart Tow Bar question
For those of you using the Bogart Tow Bar on a tail dragger, what have you done with the split pin and castle nut on the tail wheel?
The tow bar does not slip over this area and thus there is very little for it to grip onto, so I am concerned that it will pull away if not properly engaged?
Cheers
Eddie
Old 05-29-2012, 05:51 AM
N282S's Avatar
N282S N282S is offline
Default Cotter pin?
I mashed the cotter pin down just enough for the bogart socket to fit over the castle nut and cotter pin. I've seen others that are "mashed" also. Been working well for over 400hrs.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
Old 05-29-2012, 06:06 AM
Randy Hooper Randy Hooper is offline
I agree with Steve. Mash the loop end of cotter pin down and the tow bar fits perfectly and won't come off. I really like mine for it's weight and convenience.
Randy Hooper
RV-8
N84H
Old 05-29-2012, 06:15 AM
Brantel's Avatar
Brantel Brantel is offline
I replaced mine with a metal locking nut.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-29-2012, 07:26 AM
Snowflake's Avatar
My hangar mate squeezed his cotter pin enough that it allows the Bogert to clear it. He also replaced his axle bolt with one 1/8" longer and stacked a couple of washers under the head. That gives more for the Bogert to grab on the head side of the bolt.
Rob Prior
Old 05-29-2012, 10:07 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
My thought as well. Since the wheel has its own bearings around which the wheel rotates, why is a castle nut/cotter pin required in this situation?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-29-2012, 12:18 PM
pierre smith's Avatar
Default Airtractor does too.
My Airtractor has a self-locking nut on the axle as well, since the bolt is not a hinge point.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-29-2012, 02:01 PM
Thanks heaps guys, I really appreciate your responses.
Cheers
Eddie
