Old 05-26-2012, 07:57 AM
Loman Loman is offline
Default Cleveland Brake Caliper - how does it go together?
Try as I might, I could not find a clear photo of the Cleveland brake assembly. And as for Vans Drawing C2, well the less said about that the better.
Here is a photo of my two main gear legs, each with the lugs/sleeves on the Cleveland mounting flange mounted in a different direction.
The one on the right (the left hand gear leg) has the two lugs/sleeves of the Cleveland mounting flange facing inboard, away from the wheel and towards the main body of the caliper assembly. This has the advantage that the support for the caliper body seems to me to be better. However, the Cleveland flange does not lie very well against the U403 Vans flange because the chamfer on the Cleveland flange is facing the wrong way and the weld on the U403 gets in the way.
The gear leg on the left is assembled the other way around with the opposite advantages and disadvantages.
Which one is correct?
Supplementary question: I think the Cleveland flange is mounted on the wrong (inboard) side of the Vans U403 flange. Is this so? Surely there is huge interference with the 5/16ths washers if it is put on the other side?
Loman O'Byrne
RV9 TU. O-320-E2D. Engine hung, working on FWF, Arklow, Ireland
=VAF= dues paid through Dec 2020
Old 05-26-2012, 08:35 AM
Rupester Rupester is offline
Default I can't tell much from the photo, but ...
... it DID take a lot of staring at the Vans prints before I understood how all that went together. It is - for sure - not intuitively obvious. I think if you look at the prints a bit more and try flipping some parts around (i.e. aft to front, L to R, etc) , you'll figure it out.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 05-26-2012, 12:41 PM
gasman gasman is offline
The one on the right is correct. But it doesn't look like it is clocked properly.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 05-26-2012, 03:46 PM
AX-O's Avatar
AX-O AX-O is offline
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 05-26-2012, 03:55 PM
AltonD's Avatar
AltonD AltonD is offline
A picture is worth a thousand words.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
