Originally Posted by bobmarkert
First fuel tank is completed and starting on #2. Unless somebody has a good reason not to, I?m going to attach the T410 reinforcement plates to the T703 end ribs before attaching the ribs to the skin. I?ll make sure the rivet pattern does not interfear with the rivets in the T703 ribs. On the first tank it was a bit of a mess with the proseal installing the reinforcements plates after the ribs were in.
Bob Markert
RV-8 Slow build
I concur with you on this issue, I am at the same stage.
Installing those plates after tank assembly is a very messy job. The outboard plate certainly can go in before tank assembly and I plan to do the same at the inboard rib also, just have to make sure there is room to set the skin to rib rivets.
