Old 05-21-2012, 08:04 AM
rocketbob's Avatar
Default Lycoming air requirements
My son and I are working on building a flow bench to do some porting and polishing on cylinders and to explore making the induction system a bit more efficient.
Does anyone know if there are any technical documents that list the air requirements in PPH for Lycomings?
I know I can calculate this assuming 100% volummetric efficiency but I'd really like to know what the real-world VE numbers are. But since the fuel flow numbers are widely known (in PPH) I'm wondering if I can just assume a 12.5:1 ratio and get the air required.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-21-2012, 08:37 AM
Years ago, I was taught 15:1 or even 16:1. But I don't know if that's correct or not.
I'd expect the the highest airflow might not occur at full power due to using fuel flow for cooling. But it might occur near there with leaning. And it might depend on the carb or FI used. Maybe ask that company what to expect....
Dave
Old 05-21-2012, 09:38 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I think LyCon might have that info, or Airflow Performance.
You might try checking with them.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-21-2012, 10:09 AM
PerfTech's Avatar
PerfTech PerfTech is offline
The best way is to just use the standard stoichiometric calculation at 14.7 to 1 mixture and .076 lb per cubic foot air weight. This is what we use to calculate the throttle bodies we build for our fuel injection systems. Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 05-21-2012, 11:26 AM
Bob,
You might try Monte (?) Barrett at Barrett engines. He has, in the past, commented on how conventional calculations aren't exactly right in the real world, how "summer engines" test differently than "winter engines". It has to do with air flow past the intake valves, and its dependency on air temperature (speed of sound changes with air temperature).
It's complicated.
Old 05-21-2012, 07:34 PM
LarryT LarryT is offline
Default Volumetric efficiency...
... is unlikely to exceed 100% at the low speeds our aircraft engines turn, Bob, and probably is less.
Some naturally aspirated auto racing engines can actually reach 120 - 125% volumetric efficiency but they have to turn 8000 - 9000 RPM and use pretty sophisticated assymetrical camshaft profiles that require roller cams. For those engines, practically speaking, air flow is almost continuous. Mass flow inertia affects can be wonderful when the block is strong enough, the mainbearing webs are strong enough, the rods are strong enough, the crankshaft is strong enough and supported by five main bearings, there isn't any propeller intertia, etc. I never attempted to figure out the effective CR and BMEP in one of my Super Late Model engines, but 600 HP and 475 ft-lbs of torque (on the dyno) was a lot from a small block Chevy in 1981.
I admire your intellectual curiousity and look forward to seeing what you can learn with a flow bench.
Larry Tompkins
N544WB RV-6A
W52 Battle Ground, WA
Old 05-22-2012, 05:15 AM
pierre smith's Avatar
Default Nascar?
Rick Hendrik's engine builders maybe They create a pushrod motor that turns 9,000 revs +.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-22-2012, 09:39 AM
Don at Airflow Don at Airflow is offline
Default BSAC
For a Lycoming use around 6 lb/hp mass air flow.
Don
Old 05-22-2012, 10:09 AM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Hi Bob
Has anyone tried a supercharger on a Lycoming? Just a thought. BTW the carb is working out just fine on Miss Sandy. See you at OSH
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 05-22-2012, 10:16 AM
Mike S's Avatar
Senior Curmudgeon
Yes.
I believe G3 ignition folks are playing around with one, but there have been others also.
Mike Starkey
VAF 909
Rv-10, N210LM.
