Old 05-20-2012, 07:43 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Oil on my belly..
Well, not my belly, as large as it may be, but the belly of my RV-4.
It seems that after every flight I have some oil on the belly from the breather hose. It comes straight from the top of the crankcase and I have it cut flush with the bottom of the fuselage, next to the firewall.
I thought that it might be from me regularly doing rolls when I fly. So today I made a 0.47 flight in the calmest air I think I have ever flown in. And I made no abrupt maneuvers, no rolls, nothing but the kind of flying I would do if I was taking an 85 year old grandmother up for her first flight in a light plane.
But when I got back down to the hangar I checked, and there was oil on the belly, from the breather.
Is this normal? If so, why? Can I stop it? O-360 and I usually run 6 - 6.5 qts.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-20-2012, 08:03 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Thumbs up Problem Solved...
http://antisplataero.com/Videos.html
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 05-20-2012, 08:16 PM
ccsmith51's Avatar
Thanks, Reiley. I have their oil filter and axel nut wrenches and they are great products. I'll get in touch with Allan to discuss a separator for my plane.
Chris Smith
Old 05-20-2012, 08:27 PM
AltonD's Avatar
AltonD AltonD is offline
A suggestion:the flat breather tube is creating a venturi and drawing a vacuum on your crankcase. Bevil the tube such that it is slightly angled toward the front of the plane.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-20-2012, 08:32 PM
ccsmith51's Avatar
Thanks Alton. I'll give that a try!
Chris Smith
Old 05-20-2012, 08:40 PM
This will help for sure... there will still be some oil on the belly.
Reiley
VAF# 671
Friend of the RV-1
Old 05-20-2012, 08:41 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Alton, is that cut such the breather is slightly pressurized (air goes into it)?
Old 05-20-2012, 08:47 PM
AltonD's Avatar
Yep. No ill effect. It is more of no vacuum sucking the oil mist out of the crankcase.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 05-20-2012, 08:48 PM
In the Van's Kit the tube is bent slightly forward and directed to the pilot side exhaust pipe with a couple of whistle slots cut into the tube.
Reiley
VAF# 671
Friend of the RV-1
Old 05-21-2012, 05:49 AM
Pat Stewart Pat Stewart is offline
Alton is spot on. That should fix your problem however a little oil is normal.
