Old 05-20-2012, 08:14 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Switch for Gretz Pitot?
Is it worth wiring up a switch for the Gretz heated pitot since it's automatic? I'm wondering if there's a point in having a dedicated switch if it's always going to be on anyway? I'm thinking that connecting it to the avionics master would provide on/off control for maintenance and if all else fails, I could turn it off manually via the VP-X.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 05-20-2012, 08:31 AM
AltonD's Avatar
AltonD AltonD is offline
On power up, it draws about 7 amps. That tails off as it heats up. The idle current is probably under 1 amp. I would still kill it if not needed. In the event of an alternator loss, I would want everything off that was not needed.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-20-2012, 08:33 AM
True, but I have an Emergency Bus switch that only includes essential electronics. In case of power issues, I would shed the avionics master and the pitot would go off with that.
RV-10
N928MT
Build Project Site
Old 05-20-2012, 09:21 AM
rleffler's Avatar
rleffler rleffler is online now
I put it on a switch on the vp-x. Some h ow I manage to still have one open switch port on the vp-x.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-20-2012, 10:10 AM
Rupester Rupester is offline
Default Makes sense to have a switch ...
I put mine on a toggle. I always want the ability to manually kill unwanted loads. My concern was the unit failing in a way that left it on all the time. $5 for a toggle; easy decision.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 05-21-2012, 09:08 PM
Since I am using the box, I think for the rare times I need to kill it, I can do it from the efis. I'm a little low on switch space and given the automatic nature, I'll forgo the switch.
RV-10
N928MT
Build Project Site
