Originally Posted by CharlieWaffles
Yup, they are an official retailer for aveo. I talked with them and they don't sell or know much about the dual led switches because they aren't part of the aveo line.
That's weird. That's where I *got* the "special" switch I have...they had the list of them and had them available long before ACS did.
Very strange, but then...not atypical in my experience viz-a-viz vendors to the aviation community (especially experimental).
ETA: Here is the complete list of special switches which I received from Kestrel-Air back early last year:
AVEO Part Numbers Description position pcs
AVRR-01-BP-12RR Switch bottom part 12V Red/Red LED ON - - - ON 20 DPST
AVRR-01-BP-12GR Switch bottom part 12V Green/Red LED ON - - - ON 20 DPST
AVRR-01-BP-12BR Switch bottom part 12V Blue/Red LED ON - - - ON 20 DPST
AVRR-01-BP-12WR Switch bottom part 12V White/Red LED ON - - - ON 20 DPST
AVRR-01-BP-12RW Switch bottom part 12V Red/White LED ON - - - ON 20 DPST
AVRR-01-BP-12GW Switch bottom part 12V Green/White LED ON - - - ON 24 DPST
AVRR-01-BP-12BW Switch bottom part 12V Blue/White LED ON - - - ON 22 DPST
AVRR-01-BP-12WW Switch bottom part 12V White/White LED ON - - - ON 26 DPST
AVRR-02-BP-12-R Switch bottom part 12V Red LED ON - - - (ON) 19 DPST
AVRR-02-BP-12-G Switch bottom part 12V Green LED ON - - - (ON) 20 DPST
AVRR-02-BP-12-B Switch bottom part 12V Blue LED ON - - - (ON) 20 DPST
AVRR-02-BP-12-W Switch bottom part 12V White LED ON - - - (ON) 20 DPST
AVRR-02-BP-12RR Switch bottom part 12V Red/Red LED ON - - - (ON) 20 DPST
AVRR-02-BP-12GR Switch bottom part 12V Green/Red LED ON - - - (ON) 20 DPST
AVRR-02-BP-12BR Switch bottom part 12V Blue/Red LED ON - - - (ON) 20 DPST
AVRR-02-BP-12WR Switch bottom part 12V White/Red LED ON - - - (ON) 20 DPST
AVRR-02-BP-12RW Switch bottom part 12V Red/White LED ON - - - (ON) 20 DPST
AVRR-02-BP-12GW Switch bottom part 12V Green/White LED ON - - - (ON) 20 DPST
AVRR-02-BP-12BW Switch bottom part 12V Blue/White LED ON - - - (ON) 20 DPST
AVRR-02-BP-12WW Switch bottom part 12V White/White LED ON - - - (ON) 20 DPST
AVRR-11-BP-12-G Switch bottom part 12V Green/Green LED ON - OFF - ON 20 DPDT
AVRR-11-BP-12-W Switch bottom part 12V White/White LED ON - OFF - ON 20 DPDT
AVRR-11-BP-12-B Switch bottom part 12V Blue/Blue LED ON - OFF - ON 20 DPDT
AVRR-11-BP-12-R Switch bottom part 12V Red/Red LED ON - OFF - ON 20 DPDT
AVRR-22-BP-12-R Switch bottom part 12V Red/Red LED (ON) - OFF - (ON) 20 DPDT
AVRR-22-BP-12-G Switch bottom part 12V Green/Green LED (ON) - OFF - (ON) 20 DPDT
AVRR-22-BP-12-B Switch bottom part 12V Blue/Blue LED (ON) - OFF - (ON) 20 DPDT
AVRR-22-BP-12-W Switch bottom part 12V White/White LED (ON) - OFF - (ON) 20 DPDT
AVRR-01-BP-24BW Switch bottom part 24V Blue/White LED ON - - - ON 2 DPST
AVRR-01-BP-24GW Switch bottom part 24V Green/White LED ON - - - ON 4 DPST
AVRR-01-BP-24WW Switch bottom part 24V White/White LED ON - - - ON 6 DPST
AVRR-11-BP-24-R Switch bottom part 24V Red/Red LED ON - OFF - ON 1 DPDT
