Old 05-19-2012, 12:40 PM
chepburn's Avatar
chepburn chepburn is offline
Default Snap! (Followed by cursing)
Hi all,
Well, with 2.9 hours left to go in my phase 1, and a beautiful long weekend ahead, it figures that something would try to delay me.
Anybody ever had this happen? Engine Started....now, Avionics ON. EFIS On ---SNAP
These are Tyco switch breakers. (New ones!!!) Yup. The toggle broke right off at the root. C$%p.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 05-19-2012, 12:54 PM
mannanj's Avatar
mannanj mannanj is offline
Default Ouch
No. Six years and mine are still working.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 05-19-2012, 01:46 PM
Default able to fix in flight?
Chris, I have never seen that happen even in a junior high shop class! Are you able to jam something in and make it work? I would try it and see if it is easy to make it work. If not, I would change the switched to something that if it broke, it was still workable. Maybe there isn't a switch like that, but you have sure given me something else to worry about!!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 05-19-2012, 02:13 PM
At about 5 hours since new, I started up, turned on the alternator field switch-breaker (Tyco), but it immediately tripped. Wouldn't stay on. Fortunately I was only 10 minutes from home base so I flew home on battery power only, minimal avionics on. At home I found a large chunk of plastic had broken off the back of the breaker. I replaced it, no further problems.
If I had been on the road I would of had to borrow a different CB - maybe the landing lights - and jumpered that to the alternator field wire.
Old 05-19-2012, 04:06 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Years ago, I had a flap toggle switch break of just like that - but it was on a trainer that had about a gazillion student touch and goes logged......
My guess in your case is that it was just a random flaw in the metal of the bat.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-19-2012, 04:28 PM
Snowflake's Avatar
I'm inclined to agree with Paul... Probably just an extremely rare deformity or void in the metal of the bat. Unless you kind of "hulked out" for a second when you went to flip that switch... "Hulk want EFIS NOW!"
Rob Prior
Old 05-19-2012, 05:45 PM
Kevin Horton's Avatar
Crud. Mark told me you were hoping to finish your 25 hours today, and I was rooting for you. I'd be trading that switch/breaker for one on a system you don't need this weekend, if there is one of the correct rating available - e.g. nav lights.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 05-19-2012, 06:03 PM
chepburn's Avatar
Hi Kevin,
Yup, that's why I ended up doing. I now have a inop Turn Coordinator and a couple of 5 amp breakers on order.
Got 1.6 in today. Back up tomorrow.
Chris
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 05-21-2012, 03:17 PM
CopterJohn CopterJohn is offline
I ordered these from Stein for use as avionics 1 and 2... and two have broken so far. Cheap construction for a $30 switch.
Old 05-21-2012, 03:45 PM
GusBiz's Avatar
GusBiz GusBiz is offline
Default Green and mean
I think everyone can see that it was a Hulk moment.
It happens to me all the time.
Its upsetting for my accountant at tax time.
"I owe what??!!"
"HULK NO LIKE....HULK SMASH"
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
