Old 05-17-2012, 09:39 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Materials Needed for Empennage Tips?
Hello, could use a little help here....
I figure upcoming 3 day weekend will be good to make progress on my fiberglass tips; wings won't be shipping for a few more weeks...
Therefore, i'm going to need to put in an order for the fiberglass & filler type materials that will be needed right? Which is where I could use some advice. I've been doing research, watching videos, etc. then went to Aircraft Spruce only to find hundreds of different options. Rather than rack my brain, I figured someone here could probably rattle off the tip of their tongue what materials I'll need to complete the fiberglass tips on the Emp kit of my -9A
So, any advice as to what products I need to arm myself with for the task would be much appreciated. (glass cloth, epoxy, flox, etc). What's the most common? I'm referring mostly to fiberglass & filler materials, not necessarily attachments, rivets, nut plates etc. (click bond plate nut fasteners on order).
Any thoughts?
Derek
RV-9A
Old 05-17-2012, 11:25 AM
bruceh's Avatar
bruceh bruceh is offline
Derek,
I used aluminum from the trim bundle to fill in my tips. Tacked it down with proseal, but any 5 minute epoxy would suffice. Then I mixed up some flox to really get it bonded in place on the inner surface with a big fillet. The outer surface was filled with micro and sanded flush with a bit of a concave surface to accomodate the throw radius of the control surfaces.
The epoxy I used was West Systems. You should be able to find this at West Marine. I've got plenty of flox and micro if you need it.
Bruce Hill
2020 VAF donator
