High Pmag RPM drop?
I have two pmags installed on an O-360, carb and fixed pitch Sensenich. I had a 100 rpm mag drop on the right mag and 40-50 on the left. Brad suggested I check all the wires for security. I found that a couple of wire in each mag had loosened up. I turned the screws at least a half turn or more on most of the connectors. This solved my problem, both mags 40-50 mag drop at 1400 rpm and leaned for altitude. Also pull the 6 wire connector and reset and insure the two screws are tight on both mags. Dan.
