Stuck fuel float
I started a fuel calibration for my Dynon Skyview. The left wing went great, allowing me to calibrate the guage every 2 gallons.
Then I did the right, but the sender voltage wasn't changing as fuel was added. The Dynon flagged me on this. My partner shook the wing a bit and the voltage jumped, but remained unchanged as we added more fuel. I terminated the calibration after 6 gallons and after more wing shaking didn't help.
The voltage reading was near what the other sender was indicating for a low fuel indication, so my guess is that the float is stuck or some how locked up. It has been in the wing for over 4 years. Any chance it might unstick itself over the next few days? I am sure not relishing having to remove the tank and tear into it!
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
