Issue Resolved
I talked to Don at AFP and he gave me instructions on how to test the system. Instead of disconnecting the input fuel line at the throttle body, he had me disconnect the inlet line at the flow divider. The line was then routed to a container and with the throttle open and full rich mixture, the pressure stabilized at 31 PSI. After moving the mixture to idle/cut-off the pressure remained constant at 31 PSI, so everything looks okay.
From what I understand, the bypass valves in the engine driven pump cause the pressure to backup on the downstream side of the boost pump, therefore the relief valve never sees the necessary 25 PSI differential needed to open and regulate the pressure. This can't happen when the engine is running, so it's really a non-problem.
Great support from Don at Air Flow Performance!
Ken Howell
Evans, Georgia
RV-7 N92LT - Based at Thomson-Mcduffie airport HQU
TMXIO-360, Dynon Skview
Flying since June, 2012
Reason: terminology
