Old 05-14-2012, 09:46 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Worth Upgrading Alternator?
I have heard that a good planning base line is that your amperage load shouldn't exceed 80% of the Alternator output. According to the Vertical Power planning tool my load is at 52.6 Amps and the stock alternator on my engine is 60A. The 80% puts the max at 48A.
However, my load includes several ACCESSORIES that will not necessarily be used regularly or for extended period of time. For instance, I have two accessory power plugs (cigarette power plugs) to be able to charge a phone, ipod, etc... I have those down for 2 Amps each. So right there I'm at 48A if they arent used. While other things are short period - landing lights, taxi lights, etc... But they are not truly intermittant (flap motor, trim servos, etc...)
So, is it worth selling the stock alternator and buying a 70A alternator to cover ALL these items and assume they are in use at all times?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 05-14-2012, 09:56 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Mark,
Very doubtful if ever you would run out of electrons. Plus, you have a battery, right? Fly it and you will soon know. Stuff like this got me off track a lot, maybe that's why my RV build took six years.. :=)
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 05-14-2012, 10:36 PM
Thanks Jerry. The benefit of traveling for work is it makes me think ahead in my build. If I know I am going to need more amps now, I can sell the unit as new. If I wait and fly it and find I am too low, then I have to sell as used.
RV-10
N928MT
Build Project Site
Old 05-14-2012, 10:44 PM
VERY good point... I would love to have a 10... So many aircraft, so little time...
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 05-15-2012, 04:12 AM
rleffler's Avatar
rleffler rleffler is online now
With out seeing your entire list, it's hard to give a specific recommendation. I'm in a very similiar situation, as I suspect many RV-10 drivers are too. I decided to stay with the 60a for awhile.
This decision was reached by talking with other flying RV-10 builders to understand their average flying current draw as oppose to their predicted current draw per their plans. I think some of the ratings may be conservative and will yield more headroom.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-15-2012, 08:46 AM
N15JB N15JB is offline
I don't remember what my calculated load was, but my all electric panel with most of the bells & whistles draws 28-30A with everything running, including heated pitot and tablet pc. A little higher when actuating flaps and/or landing lights.
Jim Berry
RV-10
Old 05-15-2012, 08:54 AM
Strasnuts Strasnuts is offline
Default I was worried too
I thought I had a lot of amps being used and was worried about the alternator but after 200 hours I never see more than 32 amps and I have two cig. adapter chargers, heated seats, pitot, (4) HID lights, full IFR panel and so fourth. Normal cruise I see about 18, If I turn a bunch of stuff on I will see around 32. I wouldn't worry about a 60 amp like mine.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 05-15-2012, 09:09 AM
Cool, I'll stick with the stock one and see what it turns out to be and upgrade if needed later.
RV-10
N928MT
Build Project Site
Old 05-15-2012, 04:02 PM
MCA's Avatar
MCA MCA is offline
"Mark"
The final test when you're doing your phase 1 flying is to turn everything on and watch the voltage. If it stays steady over time, then your alternator can provide the necessary current. If it starts to drop then it can't provide all the power and you need to upgrade (or just don't turn everything on).
Each alternator vendor rates the alternators a bit differently, and some will certainly provide the full rated power. So I agree that waiting until you're flying and testing before making a trade-out decision is the way to go.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 05-15-2012, 04:07 PM
Thanks Marc, it was your presentation at OSH last year I even learned about the 80% guideline. If I have learned anything during the course of my build is if it's anything electrical, your opinion is the one I trust.
RV-10
N928MT
Build Project Site
