In the real world
In the real world as long as the the conatiner is sealed, as long as it is not exposed to UV which is what can causes the cross polimerisation or "gumming" as EAA puts it, and as long as it is kept relatively cool then you will be OK for even 2 years.
If your keeping it in an open glass jar, on the end of a tarmac witht eh weather being 108 then I don't think that would last even 4 months.
As a hint, if you don't have Nitrogen you can blow carbon dioxide into the container, if you have it some where in a relatively pure form ie bar keg bottle.
its heavier then Oxygen and is really unreactive. It will give you a good low oxidation buffer.
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
