Old 05-14-2012, 12:28 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Default Help. Crank Flange Bushing Removal tool and technique
I have the need to remove some/all crank flange prop bolt bushings on my lyco for a prop clocking project. I toyed with this some time ago with a bolt and some oversized nuts and washers to pry it out but was not able to get one out. I need to remove 6 of them.
The gismo I made should have worked but didnt.
There is supposed to be a tool for this but I have never seen one, and cant find one on the web.
So 2 questions.
1. If you have experience removing these please lend me your technique. Big hammers? Heat? Right tool?
2. If you have one of these tools to lend out I would appreciate that too, or point me to where I can find one.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 05-14-2012, 12:44 PM
jrs14855 jrs14855 is offline
Default bushings
A socket that will fit over the bushings, threaded rod at least 1/16" smaller than the bushing inside diameter and some nuts and washers. Socket goes behind the flange, threaded rod thru the socket and bushing, nut and washer on each end.Hold the nut on the back and turn the nut on the front.Technically I don't think you are supposed to reuse the bushings after removal.
Old 05-14-2012, 12:50 PM
Mel's Avatar
Mel Mel is offline
There's no reason not to reuse the bushings, assuming they have not been damaged.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-14-2012, 01:19 PM
Default bushings
Yeah, its probably just Lyc trying to sell some more expensive parts, just like the non stretch connecting rod bolts.
