Old 05-13-2012, 08:29 PM
glenn654 glenn654 is offline
Default 4130 question
I want to make an exhaust pipe hanger from a piece of 3/8 4130 tube,
can I cold form it or do I have to heat it with a torch?
Want to flatten each end.
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 05-13-2012, 08:33 PM
g zero g zero is offline
Prone to crack if flattened cold . Easy to heat cherry red with a propane torch, even dull red would work .
Old 05-13-2012, 09:22 PM
jrs14855 jrs14855 is offline
Default flattening
Grind and or file a nice radius on a couple pieces of angle iron. Use these in the vice to flatten the ends while hot. You don't want any tool marks or sharp edges while flattening. After flattening heat it up again and cool it down slowly by slowly backing the torch away. If you have access to welding equipment a .050 insert in the end adds a lot of strength. Flatten part way, add the insert, flatten the rest of the way and edge weld the end.
