Old 05-13-2012, 01:04 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Fuel Leak from FT-60 (Red Cube)
Hey - I've ran my engine several time now, and have found a slow fuel leak at the FT-60 (Red Cube) fuel flow transducer.
I have removed the transducer and the nipples, cleaned everything up, goobered the fittings up with Permatex #2, and reassembled it a couple of times only for the leaks to remain.
The fittings only seem to leak when the engine is running. If I pressurize the fuel system with the fuel pump, I am not seeing any leaks.
I'm about 99% sure that I did not overtighten the fittings, as I just took them snub, they added about 1/2 a flat of additional rotation.
Does anyone have any idea as to what could be the problem?
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 05-13-2012, 01:42 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default leaks
Is it leaking at the threaded connections?
What type fittings are you using, alum or steel?
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-13-2012, 01:45 PM
UnPossible's Avatar
Steel fittings - leaking at the threaded connetctions going into the FT-60.
Jason
Jason Tremble
Paid for 2020
Old 05-13-2012, 03:13 PM
Jason----not likely, but look for a crack in the treads. The red cubes are alot thicker that the older transducers that would crack if you overtightened the AN fittings. Tighten them down. The NPT threads seal by the thread taper, so a good sealer is required.
Tom
Ridgeland, SC
Old 05-13-2012, 03:49 PM
Walt's Avatar
Walt Walt is offline
From the install manual:
DO NOT EXCEED a torque of 15 ft. lbs. or screw the fittings tighter than two full turns past hand tight, whichever happens first.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-13-2012, 04:50 PM
Walt---I'm thinking Jason took them to snug and alittle bit, and doesnt have enough torque on the fitting. I agree with you.
Tom
Ridgeland, SC
Old 05-13-2012, 05:14 PM
Pat Stewart Pat Stewart is offline
I would start with the flares on the aluminum fuel lines.
Pat
Old 05-13-2012, 05:58 PM
Walt's Avatar
Originally Posted by TS Flightlines View Post
Walt---I'm thinking Jason took them to snug and alittle bit, and doesnt have enough torque on the fitting.Tom
That's what I was thinking too, most folks have a tendancy to under torque pipe fittings hence the torque for this comes in as a handy reference.
Old 05-13-2012, 08:04 PM
UnPossible's Avatar
Tom
Tom - I think you are right.... I think I was afraid of over Torqueing them... I took out the Red Cube and went out and bought a deep well 5/8" socket that will fit the fittings.
Looking at the instrucitons I have, they say not to torque over 25 ft lbs. I set my torque wrench for 25 ft lbs, and the fittings both spun a coupe of full rotations or more beyond where I had them before the torque wrench clicked off.....
Really hoping that this fixes my fuel drip issue..... guess we'll know tomorrow evening.
Jason
Jason Tremble
Paid for 2020
Old 05-13-2012, 10:24 PM
N427EF N427EF is offline
Default Red Cube fuel leak
A leaking nipple was the cause of my fuel smell issue in my RV-10.
The nipple was bottomed out in the red cube fuel meter and no amount of torque could seal the weeping leak.
I Pro Sealed it in, problem solved.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
